king pin help - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-08-2011, 06:45 PM
king pin help
I bought a 5window 30 coupe with a Chassis eng. straight axle,had some wheel balancing issues,got them fixed.Now I have somefront to back movement @ the top of the king pin. could the out of balance wheel put enough strain on it through vibration to have caused some damage ? we're talking under 50 miles. this is my first straight axle car.
Old 07-08-2011, 07:12 PM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
I very much doubt that an out of balance wheel caused the king pin to have slack. Most likely was put together with that much clearance. JMHO
Old 07-08-2011, 08:22 PM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
Hard to say what you have there, king pins should not have slop, free but no slop. A repair kit is not all that costly and an easy fix. Sometimes you can replace the bearing, king pin and seals and tighten things up. The bushing that goes in the axle should be fine, you say it only has 50 miles on.
Only 50 miles all should be Ok , but you did say there is slop. You are sure that the movement is from the spindle and not wheel bearings . Just ideas for you to think about.
The link supplied below is for reference only so that you can see what is involved.
http://www.speedwaymotors.com/1937-1...-Kit,8329.html
Old 07-08-2011, 08:36 PM
adantessr's Avatar
'23 T-Bucket Pickup
Wiki Edits: 3
Pepi. I have less than 4,000 mi on my king pins and they have more movement than I would like to see. I plan on installing the needle bearing kit this winter. It requires having the steering knuckles machined to 1.062 to 1.063 or 1-1/16" to keep it simple. Hopefully won't cost too much since that is not some oddball metric size. Should be able to be done with a reamer.
Old 07-09-2011, 05:56 PM
pepi's Avatar
Adantessr,
Who makes the needle kit I have not seen that part? I like the idea of that, over the years and 28000 I got some slop in the drivers side. I figured that was ok because the cross steer loads that side. It did not effect the bushing in the knuckle, but your needle bearing option is a nice preventive move.
Machine shop work around here is 50 an hour, I think you could get away with 75 -100, maybe 50 if you have someone that you use regularly.
Old 07-09-2011, 06:02 PM
adantessr's Avatar
'23 T-Bucket Pickup
Wiki Edits: 3
Originally Posted by pepi
Adantessr,
Pepi, you silly boy, the link that you posted is the needle bearing kit .
http://www.speedwaymotors.com/1937-...n-Kit,8329.html
I don't know what happened. When I copied and pasted it, it won't open, but if you go back to your post it opens.
Old 07-10-2011, 05:43 AM
pepi's Avatar
LOL Bigger then life !
It does say deluxe, nice catch. The king pin set I got from them was 20/30 or so ... well as I say it always pays to rtp, that really is a nice upgrade for old axels.
Thanks
King pin removal flynbrian48 Suspension - Brakes - Steering 5 06-06-2009 10:51 AM
Spitzer - The 'King' is daed, long live the 'King' Irelands child Off-Topic 4 03-12-2008 03:52 PM
king pins? minesblown Transmission - Rearend 5 12-07-2003 09:38 AM
Honesty King trees Hotrodders' Lounge 10 10-28-2003 09:06 AM
question for the KING crazy larry Body - Exterior 2 12-18-2002 06:39 PM
