King Pin Questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-05-2009, 07:30 PM
1930u's Avatar
Last journal entry: 1930u Its just been sitting
King Pin Questions
Previously I had posted in my journal that my king pins and spindles came apart with ease. Today I broke them down further removing the bushing inserts and measured everything up. The king pins themselves measure .811.
What is the free play tolerance suppose to be between the king pin and the bronze bushings? Also is there a site where I can by the new bushings, or should I just head down to the local bearing shop to buy the bushings.
ID:	42363   Click image for larger version
ID:	42364   Click image for larger version
Old 12-05-2009, 08:28 PM
king pins
King pins normally come in sets with new pins and bushings. After the bushings are pressed into the spindles they have to be reamed to the correct size. If you don't have the reamer or have never done this, it is a job for the machine shop. They will ream or hone the bushing to the correct fit to the pin.
Mark
Old 12-05-2009, 08:33 PM
BOBCRMAN@aol.com's Avatar
As an old machinist. The rule of thumb for fit is a light push with thumb. Usually between .0005 to .001" Done on a Sunnen hone. The reamers tend to be a bit more loose.
Most of the old Ford stores have either bushing kits or king pin kits. Try Macs. or www.Speedwaymotors.com. Also has kits.
Old 12-05-2009, 09:13 PM
1930u's Avatar
Mark
These are floating bushings. Their split and easily push in with only hand pressure. I pressed them out with a socket's and a vise. They came out with very little pressure. They have a steel backing with bronze sleeve. I don't think this type requires reaming.
Thank you.
Old 12-05-2009, 09:15 PM
1930u's Avatar
Thank you exactly what I needed to know.
Questions on floating or pressed fit pistons and rods for SBC 350 eric32 Engine 7 10-30-2015 07:21 AM
Wrist pin ...cannot decide!!! rockher_man Engine 4 12-02-2009 08:33 AM
King pin removal flynbrian48 Suspension - Brakes - Steering 5 06-06-2009 10:51 AM
New rule in the engine forum, PLEASE READ! 4 Jaw Chuck Hotrodders' Lounge 41 01-12-2009 07:21 PM
The King of Trid Kevin45 Hotrodders' Lounge 3 12-09-2002 07:12 PM
