kirker base/clear question - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-24-2012, 02:20 PM
I've been searching and can't find the answer. I'm painting my hood on my daily driver with kirker super jet black paint. I painted my hood a couple days ago and I had some orange peel in the base so I sanded it with 600. I have clear that came in the kit and was wondering if I could just put the clear on the sanded basecoat (the tech sheet says to to sand the surface with 600 if the paint is cured before clearing) but I'm worried that it won't fill the sand marks. Or should I put another coat of base then clear it after it flashes?
It says I need to wait 8 hours until I color sand/polish the clear but would 24 hours be ok?
Old 08-24-2012, 03:01 PM
If its a metallic paint then you have to shoot abother coat of base or you will see it through the clear, for a solid color ive gotten away with it but if you can shoot the base and then clear imo it should come alot nicer
Last edited by monster76; 08-24-2012 at 03:05 PM. Reason: Phone key board to small
Question about touching up Base Coat/Clear Coat TR4AGuy Body - Exterior 0 10-08-2011 02:57 PM
sanding clear then repaint with base clear agian questions tiptopss Body - Exterior 8 04-20-2010 07:09 AM
Some questions on Kirker clear coats Bettlejuice Body - Exterior 5 07-03-2009 10:53 PM
Nason base over kirker 2k 68442 Body - Exterior 5 03-26-2007 12:12 AM
Mix Clear with Final Base coat prior to clear x711 Body - Exterior 10 04-08-2006 07:55 AM
