knock knock - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-07-2007, 07:42 AM
1cleanmav!'s Avatar
knock knock
the front suspension on my maverick does alot of knockin when i go over bumps it event does it on rough parking lot asphault and when i go around a tight curve or when i turn i hear a clicking sound coming from the suspension
can anyone help me with this problem before it drives me crazy
Old 12-07-2007, 08:36 AM
31 five window
Last journal entry: grill and rear end
I think mavericks have strut rods just like mustangs,check these bushings.
Old 12-07-2007, 06:26 PM
Wiki Edits: 31
yup, they have strut rods, they can be a problem.. also... what happened to me w/ my '67 Falcon ( same basic chassis design ), when I got it, the suspension was 100% fine, worked fine, shocks, springs.. everything checked out fine.. but going over bumps and even just down the road, the passanger front would just clunk like it was coming apart.. I figured the shock was clunking, so I went and got a new 1. when I went to pull the bottom bolts out of the shock, the 2 rubber bushings that keep the shock stable and quiet, were missing.. I pulled the top 3 bolts out of the strut tower ( easiest way to remove the shocks ), and removed the strut, slapped the new strut in, put the bolts in w/ new bushings and put it back togther ( would be a 10 min job if it wasn't for a pressed in- spinning shock mount stud ( quality these days ), that I had to replace w/ a bolt of the correct size and hold w/ a wrench. anyway, the car now the car is clunk free.
Old 12-07-2007, 06:36 PM
poncho62's Avatar
Wiki Edits: 5
Check your sway bar links.
Old 12-15-2007, 02:50 PM
New Member
have you checked the upper A-arm bushings? They are a PITA if they are still the stock metal on metal bushings. I replaced mine with moog rubber bushings
Shaun
Knock in my Chevy Bugs Engine 29 01-12-2011 04:08 AM
Knock Knock.....sigh.... JamesRS Engine 8 04-24-2006 05:29 PM
Chevy 350 knock driver side? Help jimenezaldo Engine 18 09-01-2005 04:38 PM
Help!!! Knock, Knock, Knock coming from tranny 70bird Transmission - Rearend 1 05-06-2004 12:30 AM
rod knock? rebuilder? Engine 5 11-01-2002 09:59 PM
