I guess there is a first for everything, I've never personally seen a bad knock but its verry possible, the effects of a bad knock sensor could vary like timing retard and such. But there are 2 knoc sensors screwed in to the knock sensor plate which is located under the intake, they are pluged in to a small harness that leads to the rear of the intake, its a small plug mabe you could just un-plug and plug back and try scan again or re-boot comp. what is it acting like?
