knock sensor - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-23-2006, 03:03 PM
knock sensor
Where is the knock sensor located on a 2002 chevy silverado with a 6.0 engine. I looked everywhere that I was told before and its not there, but there is one somewhere.
Old 05-23-2006, 03:27 PM
1931 steve's Avatar
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
Your engine has two of them and both are under the intake manifold.
Steve
Old 05-23-2006, 03:32 PM
knock sensor
I was told that also, the intake is not aluminum or cast, it is made out of some kind of plastic and I was told they do not mount them there, If its under the intake, do I have to pull the intake off or is it mounted on the block. Thanks
Old 05-23-2006, 04:02 PM
1931 steve's Avatar
Wiki Edits: 4
Remove the intake and you will see two rubber grommets that have wires going through them. Under the grommets you will find knock sensors. Sorry to say yes the intake has to come off.
Steve
Old 05-23-2006, 06:52 PM
is that the same on a 99 5.3
will a bad knock sensor cause the_sellars Engine 0 02-08-2005 05:43 PM
knock sensor question Old School Nut Engine 14 09-15-2004 08:50 PM
Knock Sensor Confusion bluesman123 Engine 16 02-26-2003 05:12 PM
Moving an LT-1 Knock sensor Bumpstik Engine 0 02-15-2003 05:52 PM
10. to 1 Knock sensor??? catdad2u Engine 6 11-14-2002 12:01 PM
