knock sensor - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-18-2006, 09:19 PM
knock sensor
where is the knock sensor located on 1999 chevy silverado 5.3L vortec?
Old 06-18-2006, 09:54 PM
spankys rod shop's Avatar
You should find (2) just under the intake manifold with the plug in the rear. one plug on a small harness that leads to both sensors.
Old 06-18-2006, 09:57 PM
so its in back of the intake? how does it look like?
Old 06-18-2006, 10:00 PM
mabe it would be quicker to tell me what you are trying to do?
Old 06-18-2006, 10:04 PM
i went to advanced auto parts so they could scan my truck with the diagnostic code thing and it said that there was a problem with the knock sensor and im tryin to look for it. and just to make sure what are the side effects of a no good knock sensor
Old 06-18-2006, 10:13 PM
I guess there is a first for everything, I've never personally seen a bad knock but its verry possible, the effects of a bad knock sensor could vary like timing retard and such. But there are 2 knoc sensors screwed in to the knock sensor plate which is located under the intake, they are pluged in to a small harness that leads to the rear of the intake, its a small plug mabe you could just un-plug and plug back and try scan again or re-boot comp. what is it acting like?
Old 06-18-2006, 10:19 PM
when i stomp it at a dead stop it doesnt respond like it used to before it would take off burnin out alot and accelarate quick now it jus takes off really slow and revs up super slow what do u think?
Old 06-18-2006, 10:25 PM
I gotta go for now but try to find someone with a tech II scanner with a good understanding how to use it and i'm sure you'll get to the bottom of it.
Old 06-18-2006, 11:56 PM
StevenC's Avatar
You could have another issue causing a problem and making the engine ping setting off the knock sensor. Like a chain reaction it will all go down hill. I personally never have seen a bad knock sensor.
knock sensor corsair1961 Engine 4 05-23-2006 06:52 PM
knock sensor jo5hi3 Engine 1 10-28-2004 02:59 PM
knock sensor question Old School Nut Engine 14 09-15-2004 08:50 PM
Knock Sensor Confusion bluesman123 Engine 16 02-26-2003 05:12 PM
10. to 1 Knock sensor??? catdad2u Engine 6 11-14-2002 12:01 PM
