knock sensor problem.....:( - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-28-2011, 08:01 AM
old yukon's Avatar
So i though this would be a good time to take out my knock sensors and put in new ones. They say it only takes a few hours.
That wasn't the case for me. ( image 1)
It was more like where is the rear knock sensor, under all that rust and dirt.
After a few days, I got it out, thank God for that.
I cleaned the cavity, but found the walls were damaged, partly due to rust and partly me. ( see image 2).
Cant tell if the walls are punctured or OK.
Question - would there be a problem if I put in the new knock sensors, wires etc. if there is a a few small holes in the cavity of the valley cover?
I would really appreciate an answer form those who really know their stuff.
Thanks in advance.
Name:	rusted knock sensor.jpg
ID:	53106   Click image for larger version
Name:	knock sensor cavity2.jpg
Old 02-28-2011, 10:25 PM
old yukon's Avatar
let me put it a different way.
If there are a few small hole in the valley cover plate, would that be a problem?? ( click image )
Name:	valley cover plate removed.jpg
Old 02-28-2011, 11:48 PM
Race The Truck
Last journal entry: Son's Truck
Try this site more in to this type of thing www.fullsizechevy.com
Old 03-01-2011, 10:46 AM
old yukon's Avatar
Does anybody here know anything about what goes on under the the valley cover under the intake manifold??
Here is my guess work on this scenario.
1. The area under the valley cover is pressurized.
2. The area under the valley cover contains oil at high temps.
3. the possibility of small holes in the knock sensor cavity will cause oil to seep into the cavity flooding the knock sensor, and eventually run over the front and rear of the engine and transmission, onto the ground.
4. I will have to to go back in and do a big clean up job and repair.
How does that sound ??
Old 03-03-2011, 04:21 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The valley cover seals the crankcase. If there are holes in it, it should be either repaired or replaced.
Old 03-03-2011, 04:43 AM
old yukon's Avatar
thanks for that cobolt.
I heard the gasket can be reused, what do you think?
Old 03-03-2011, 04:53 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Yes, you can reuse it. Obviously it needs to be in good shape, but I wouldn't worry a bit about reusing it.
Old 03-03-2011, 05:10 AM
old yukon's Avatar
Thats good news!
Question once in there, is there anything else I should be also looking at ??
Old 03-03-2011, 05:26 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by old yukon
Thats good news!
Not really.
Some guys have said converting the LS1 PCV system to the LS4 system is a better way to go about it. This requires some grinding of the block under the valley cover to use the LS4 valley cover. The LS4 cover has an oil separation chamber that is used instead of the valve cover mounted LS1 PCV system. But if the engine's not using oil or having PCV-related problems, I would keep on using the set-up the way it is.
Old 03-03-2011, 05:32 AM
old yukon's Avatar
Sweet !
I dont need to go down that road.
leave it as is.
Knock Sensor tommy evans Engine 5 08-21-2010 07:02 PM
Knock sensor?? weirdbeard Engine 2 03-26-2006 08:08 AM
knock sensor the_sellars Engine 1 02-06-2005 04:49 PM
knock sensor jo5hi3 Engine 10 10-29-2004 02:00 PM
10. to 1 Knock sensor??? catdad2u Engine 6 11-14-2002 12:01 PM
