Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - knock sensor question
Old 09-14-2004, 08:04 AM
Odium's Avatar
Odium Odium is offline
There are two main parts to the knock detection. First is your sensor, second is your ECU module that interprates (sp) what the sensor is picking up. In my '95 Firehawk I have an LT-1 sensor, but I swapped out the knock module for an LT-4 module in the ECU because it's more accurate than the LT-1 module. As for wiring up some sort of injection system off the module itself, yea, it's possible but I can't tell you how to do it. I might not reccommend it either as false knock would activate your injection system and could cause damage.
