Knock....? (With video) - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-31-2013, 07:23 PM
https://www.youtube.com/watch?v=9VVG-uZXWgo (taken at night, more videos to come)
I was idling at 750 RPM in the video. Motor has about 1000 miles on it.
It is there all the time, cold or warm. It increases speed with RPMs but doesn't change pitch or get louder. Sounds loudest when listening from under the engine. I've listened to the motor all over with a screwdriver to my ear but I can't seem to isolate it. I set lifter preload again but no change.
I'm just wondering if this is recognizable to any of you...
Info on motor;
'98 Vortec block and heads, stock rockers, untouched heads, stock rods, new stock replacement crank
This cam: http://www.compcams.com/Company/CC/c...?csid=186&sb=2
These pistons: http://www.summitracing.com/parts/sl...make/chevrolet
These valve springs: http://www.summitracing.com/parts/crn-10309-1 (Made to provide retainer to guide clearance for vortec heads up to.550" lift)
Thanks a bunch.
Old 07-31-2013, 08:31 PM
vinniekq2's Avatar
could you post a video thats a little longer,say at least 1 or 2 minutes?
Change the RPMs and views
Old 07-31-2013, 09:54 PM
Small block chevy knock/tick - YouTube
Heres one more video.
Old 07-31-2013, 10:26 PM
vinniekq2's Avatar
I think I hear exhaust leaking and of course valve train noise.I think I hear a random thump too? My sound on the computer is not very good.
did you use a cam button? are the converter bolts all tight?
how much lift on the cam? the link does not work
Old 08-01-2013, 12:20 AM
Small block chevy ticking/knocking noise - YouTube
Heres a third longer video.
The cam is Comp cams hydralic roller XR264HR. 110 LSA, .487/.495, 212/218@.050"
This block uses a cam retainer plate so it doesn't use a cam button right?
I'll check the converter bolts.
Old 08-01-2013, 12:59 AM
thinwhiteduke's Avatar
Living In The Past
Sounds like a half speed tick so possibly valve train???
Have you done a visual check - valve train?
Duke
Old 08-01-2013, 08:59 AM
RWENUTS's Avatar
Pull the belts off and see if it goes away or spray some belt dressing on them into the pulley.
Old 08-01-2013, 03:10 PM
Rhansen's Avatar
Footbraker
sounded like valve train to me too
pull the valve covers and look
Old 08-01-2013, 07:35 PM
I had the valve covers off just two days ago to set lifter preload again to see if it would help but no difference. None of the lifters seemed to be collapsed or anything. There were no obvious signs of problems, but I guess I should go back and take off the rockers and look at em.
In my opinion it sounds like a lifter but I can't imagine what could go wrong with one (broken/seized roller??) , but I hardly have any experience with engine ticks/knocks.
Knock Knock, Its a woman! xRYKERx Introduce Yourself 38 12-23-2010 09:30 PM
Knock, knock..who's there?...... Landshark Landshark928 Introduce Yourself 3 02-05-2010 07:36 PM
knock knock........ son-of-a-biscuit !!! 79C10 Engine 10 10-18-2007 06:30 PM
Knock Knock.....sigh.... JamesRS Engine 8 04-24-2006 06:29 PM
Help!!! Knock, Knock, Knock coming from tranny 70bird Transmission - Rearend 1 05-06-2004 01:30 AM
