Knocking Comeing from my 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-13-2007, 06:53 PM
camarodude87's Avatar
Hey guys
Alright, I got a 83 camaro, I kno it never came with a 350 but I "was told" that its a 350 out of 79z28. Ran the numbers it was a 350, anyway I have a knockin noise coming from a couple of my lifters, I tighten them up, the noise went away until I started reving up the car, the knock came back. Should I tighten them down more or what???
thanks guys
Ray
Old 04-13-2007, 06:58 PM
FEDDO's Avatar
noise
good chance it is a couple of studs pulling out. common problem.
Old 04-13-2007, 07:17 PM
chiss's Avatar
Or the lifters are collapsing. Watch over tightening you'll wipe a lobe.
Old 04-13-2007, 07:19 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Unless that's already happened.
Old 04-13-2007, 07:28 PM
thanks for the help but can yall be explain what you mean
Old 04-13-2007, 07:35 PM
lookatme's Avatar
probly wouldnt be a bad idea to adjust all your rockers. the "easy" messy way to adjust them is to do it with the engine running. just loosen one up till it just starts to tick, and then tighten it back up 3/4 to a full turn.
as far as wiping a lobe, check to see if all your rockers are moving while the engine is running
-chris
Old 04-13-2007, 07:41 PM
Yea I was doin that. Noise went away, startin clean up the car reving it up and stuff all of a sudden noise came back. I was Like ***...so I tighten it up again and started hearing ******* on the driverside so I tightened those up, as soon as i was gettin ready to leave the damn thing started to knock again.
Old 04-13-2007, 07:50 PM
lookatme's Avatar
how far down did you tighten them ? it could be a collapsed lifter. .........maybe. if its a collapsed lifter, you might try loosening up your rockers gradually and see if they will pump back up before you retighten them.
Old 04-13-2007, 08:13 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Is this engine Newly Rebuilt, or has it some miles on it..?
Recent Cam Change?
Recent work on the engine?
Doc
Old 04-14-2007, 10:28 AM
the engine has some miles on, not sure if it was rebuilt, but i doubt it. I kno it doesnt have a stock cam cause when i try and set the timing from the book the car runs like *******.
Old 04-14-2007, 04:19 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
That would be a clue that the cam was going away..can't time it and clatter after adjustment.
Doc
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 03:00 PM
Cam/Lifter Question about Ramjet 350 Jake Harsha Engine 20 07-07-2010 06:22 AM
Bog/Black Smoke on Olds 350 at 3000 rpm JohnTN Engine 4 03-17-2009 11:39 AM
possible 350 block purchase - comments please idrva55 Engine 17 12-09-2007 09:29 PM
