knocking noise during idle and full throttle - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-04-2003, 12:24 AM
89camaroman's Avatar
New Member
Hi all this is my first time here. well here is my problem short and sweet. I bought a 89 Camaro RS with a 305 tbi for $600 with about 90k miles on it.When i hit 100k on it i started to get a knocking noise during initial start up and during full throttle romps. I was told it could be either 1 of 3 thing's #1 my flywheel might be cracked. #2 rod bearings. #3 main bearings any ideas about this problem would be greatly appreciated.
Also i think i may have a bad valve seal also not really sure but it smokes when i first start it and under throttle.
The motor will still burn the tires off the rims if i let it and it is actually faster to 100mph than my moms boyfriends 88 camaro lol with the same engine set-up....
Thanks for any advice i can get..
Old 10-04-2003, 03:02 AM
4 Jaw Chuck's Avatar
Rebuild time.
— Han Solo
Old 10-04-2003, 01:17 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Gotta agree there. It won't be long before she goes.
Old 10-04-2003, 01:51 PM
New Member
added info
i forgot to say that i already put almost 15k miles on it since the nock started!!!!!!
I guess ive benn biting the bullet on this one 4 awhile..
Old 10-04-2003, 01:57 PM
Continuing to drive it in this condition may cause microcracks in the crank and make it unusable, definetly have it Zyglo'ed before turning under at rebuild time. Rods don't take well to it either, hope she doesn't leave you stranded. Drive with a light foot or pull it off the road before you cause irreversible damage.
Sorry man, been there done that.
— Han Solo
Old 10-04-2003, 01:58 PM
Vetter
It might be detonation but if you been running the same octane, then it is either a rod or maybe even a valve. Does sound like you need a rebuilt. Good luck.
78SilverShark
Old 10-14-2003, 07:31 PM
New Member
WELL I DECIDED THAT I AM JUST GONNA REPLACE THE ROD AND MAIN BEARINGS. AND I HOPE THE MOTOR WILL LAST TILL TAX TIME I AM GOING TO BUY A PERFORMANCE 305 FOR 1300 DOLLARS.. WHEN I WAS TALKING TO THE GUY HE WAS SAYING THAT IT WILL BE SIGNIFICANTLY STRONGER THAN THE STOCK 305 .
Old 10-14-2003, 07:51 PM
poncho62's Avatar
Wiki Edits: 5
If replacing it, why not go with a 350. Everything bolts up.
Old 10-18-2003, 09:01 PM
ThrustfulJet's Avatar
Had same problem with my 396 inside my 70 El Camino. Turned out I had three main bearings spun. Wouldn't drive it to much if it was mine. Think It's time to rebuild.....
