Knowledge base - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders Site Suggestions and Help
Old 12-18-2009, 03:02 PM
Semper Gumby
Wiki Edits: 2
Knowledge base
I was going to use some of the stuff in the knowledge base sections to show some folks how "this" works and how "that" works, only to discover that many of the links no longer seem to work. Ditto in the "guide for beginners" section where, for example, the link to "engine system overview" now links to "Page not found"
Jon - If you would like me to (I know you're busy) I can go thru these links and give you list of the ones that seem to have gone astray in the course of time, so they can be either updated or deleted
Old 12-18-2009, 03:11 PM
Jon's Avatar
Jon Jon is offline
Hotrodders.com Administrator
Wiki Edits: 7314
Sure, thanks. Feel free to start a wiki page on this, if that's easier for you. (ie: an article titled "Knowledge Base broken links").
Old 12-20-2009, 07:06 PM
Semper Gumby
Wiki Edits: 2
knowledge base - broken links
Well so far, I have chased down every link, by category and sub-category in the "Engines" section of the Knowledge Base (Sheesh! There are a LOT of links!)
People have done a LOT of very good work in compiling this. However, over time, some have changed or are no longer valid
I was going to do it as a wiki, but for some reason, the wiki area gives me "issues", so here it is (for now). I'll go in and do the rest of the categories as well, hopefully within the next few days.
What I have found for broken, non-functioning etc links are:
Hotrodders Knowledge Base > Engine > Block, Pistons, Rods, and Crankshaft > Articles:
Connecting Rod Length and Angularity
Hotrodders Knowledge Base > Engine > Block, Pistons, Rods, and Crankshaft > Technical Data:
Rod Ratio Calculator
Hotrodders Knowledge Base > Engine > Chrysler > Discussions:
General Hemi Background and Information (THIS ONE OPENS A LINK TO ADVERTISMENT FOR OFFICE FURNITURE!)
Hotrodders Knowledge Base > Engine > Chrysler > Technical Data:
Hemi Engine Specifications and Casting Numbers
Hotrodders Knowledge Base > Engine > Cylinder Head > Articles:
1969 Ford Cylinder Head Rebuild
Aftermarket Small Block Ford Cylinder Heads
DIY Cylinder Head Porting
SBC Cylinder Heads
The Watson Guide to Happy Head R&R
[B]Hotrodders Knowledge Base > Engine > Cylinder Head > Parts and Services:[/B]
All Pro Aluminum Cylinder Heads
Hotrodders Knowledge Base > Engine > Ford > Flathead > Technical Data:
Ford Flathead ID Numbers
Hotrodders Knowledge Base > Engine > Ford > Technical Data:
1979-85 Ford Mustang Engine Specifications
Early Ford Archive (Actually links to a site that is Small Block Chevy-based)
Ford 351 Windsor Torque Specifications
Ford 351-400 Engine Torque Specifications
Ford Big Block V-8 Torque Specifications
Ford Engine Numbers
Ford Engine Torque Specifications
Ford Head Flow Data
Ford SB V-8 Torque Specifications
Hotrodders Knowledge Base > Engine > Ford > Websites:
Asa Jay's 351C Rebuild
Hotrodders Knowledge Base > Engine > Fuel Delivery > Carburetor > Articles:
Carburetor Tuning Procedure
Hotrodders Knowledge Base > Engine > Fuel Delivery > Carburetor > Technical Data:
Carter AFB slection and tuning.
Hotrodders Knowledge Base > Engine > Fuel Delivery > Fuel Injection > Articles:
Basic TPI Mods (Links to a site selling cell phones)
Ford Mustang MAF Induction
Windsor Fox (LINKS TO A SEX-BASED DATING SITE in Windsor, Ontario)
Hotrodders Knowledge Base > Engine > General Engine > Articles:
455 Block Oil System Modifications and Prep Work
AMC Fuel Pump Replacement *
AMC Small Block V-8 Engines *
AMC Timing *
* all 3 of these link to a "sort of a / kind of a" AMC site, but are not what they are titled as all 3 link to the same page
Hotrodders Knowledge Base > Engine > General Engine > Parts and Services:
Engine Pro Software
Furious Racing Engines (Domain name is for sale)
Hinds Custom Machine
Larry's Performance Shop
Thumper Performance
Hotrodders Knowledge Base > Engine > General Engine > Technical Data
Cubic Inches to Liters Calculator (however, since 61.2 CID =1 liter, who needs it?)
PCV Valves
Hotrodders Knowledge Base > Engine > General Engine > Websites:
David Reher Engine-Building Drag Racing Articles
Hotrodders Knowledge Base > Engine > General Motors > Buick > Parts and Services:
Performance Automotive Engines
[B]Hotrodders Knowledge Base > Engine > General Motors > Chevrolet > Technical Data[/B]:
Chevrolet Camaro Engine Codes
Hotrodders Knowledge Base > Engine > General Motors > Oldsmobile > Discussions
Early Olds Rocket Tech Summary
Hotrodders Knowledge Base > Engine > General Motors > Technical Data:
GM SB Cylinder Head Marks
GM V-8 Casting Numbers
Hotrodders Knowledge Base > Engine > Ignition:
Bosch Spark Plugs and Spark Plug Wires
Hotrodders Knowledge Base > Engine > Intake > Intake Manifold > Articles:
Small Block Intake Manifold Survey
The Watson Guide to Happy Intake Manifold Swaps
Hotrodders Knowledge Base > Engine > Oiling > Articles:
Engine Oil Notes
Oil Treatments -- Snake Oil or Not?
Canton Racing Products
Hotrodders Knowledge Base > Engine > Supercharger > Articles:
Holley Supercharger General and Technical Information (This goes to the Holley site, but I wandered around that site and could not find any info on superchargers
[B]Hotrodders Knowledge Base > Engine > Supercharger > Websites[/B]:
The McCulloch Supercharger Website (site is closed, domain name is for sale)
Hotrodders Knowledge Base > Engine > Turbocharger > Articles
Turbocharging a Small Block Ford
Hotrodders Knowledge Base > Engine > Valvetrain > Parts and Services
Reed Cams (shows page as "under construction - come back soon")
What causes paint failures? MARTINSR Body - Exterior 57 07-15-2008 09:49 PM
Knowledge base lluciano77 Hotrodders Site Suggestions and Help 1 12-10-2004 07:21 PM
Knowledge Base Nightfire Hotrodders Site Suggestions and Help 2 07-27-2004 02:21 PM
Knowledge base question about Isky cam? slider in wa Engine 6 03-06-2003 06:53 AM
