If that compressor has reed valves quite likely you have a broken reed valve..EZ to check just pull a head and look..
Sam
Check Head Gasket
Is it going up to 50 to 70 PSI but not higher? Many of those style compressors have very thin dividers in the head gasket between the inlet and discharge valves. Sometimes those dividers fail and cause the situation you see. As ONEMORETIME mentioned it could also be a valve failure too. There is no test other than a pump up test but you can tell without a stopwatch that it is running longer than before. You need to disassemble and inspect it to determine the exact cause.
I would contact the Lowes you bought it from to see who they recommend for the service work on their compressors. You should be able to buy an entire valve plate assembly and just replace all the valves in the unit at once. That is what I recommmend. Also, after replacing the valves, run it for a while then retorque the head, then do go through that procedure again to be sure the gasket is properly crushed. |
Thanks |
I did get the reed valve assembly installed, but the copper drain tube stripped out. Surprisingly the wall in the pump is very thin and only a couple threads for the tube. They stripped out and I ended up getting an 1/8" X 2" tappered pipe thread tube and I was able to tap out the pump, stwist in the copper tube, and put a cap on it. And you are correct, very humid here in the Palmetto State. Thanks to all for the help...Have a great week. |
There may be these cheezy flap valves that are held in place by the pressure of the cylinder head and cylinder itself. These can move over time/use, and eventually have to be re-aligned. We had this POS compressor that had this problem continually, about every hour or so of solid use the head had to be pulled and the valves put back where they should be. The flex from the hot-cold temp swings & high pressures can aid this effect too. Check those out, and inspect their condition. Failing that, it may be a blocking issue in the intake or even just the piston itself. Most likely it wont be anything to do with the piston though.
I had the same problem (K7060HFV)
I smacked the head around with a rubber mallet and then ran it without the muffler while squirting some air tool oil in the intake to loosen up the valves. My problem is caused by it sitting around too much. Maybe this is all you need as well?
Thanks for the help... |
| Recent Garage - Tools posts with photos |
| Anyone have trouble with the kobalt compressor | 5dogsisenuff | Body - Exterior | 41 | 01-12-2013 01:26 PM |
| kobalt air compressor | yankee | Engine | 1 | 07-07-2011 09:41 AM |
| kobalt air compressor | yankee | Garage - Tools | 2 | 07-05-2011 12:17 PM |
| Kobalt Air Compressor | Luke Peterson | Garage - Tools | 13 | 07-14-2008 07:56 PM |
| Kobalt Air Compressor K7060hfv | J.D.ROOST | Garage - Tools | 4 | 06-08-2007 07:14 PM |
