Kohler 14 hp. problems.. - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-19-2013, 07:16 PM
BOBCRMAN@aol.com's Avatar
I rebuilt an old style Kohler 14 for a lawn tractor. I have done many of these over the years but this one is biting me real hard..
Engine ran good, just smoked REAL bad..
Bored it .020" new piston/rings.
Re-grind crank .010" exact same part no. as original.
New .010" rod.
Resurfaced head
Valve grind
New intake/exhaust valves and guides.
Rebuilt the carb. Walbro side draft.
New points set .020" New s-plug.
Went together with one minor glitch. China inch is different than American inch and replacement rod had to be opened up .0005" for correct fit.
Cam&crank timing is correct. Valve lash is correct.
Engine starts a bit hard. Will only idle with choke at full. Will not run at speeds above idle. Just knocks/backfires/pops unless you hold your hand full over the carb and regulate air flow with air leaks around hand. Has good vacuum and pulls fuel from the bowl. Won't rev over about 900 rpm. Then backfires and pops out exhaust, dies.
Acts like vac leak, but carb is bolted to the head, ! gasket.
Had carb apart twice. Everything checks out great.
Changed points to .016" no difference. Good steady spark. New coil and condensor.
Haven't got it to operating temp yet because of problem. Maybe 10 minutes total run time with dozens of starts. With a couple hours of tinkering/adjusting.
Any small engine tune up guys have an idea of what is causing the problem.. Thanks BOB
Old 06-19-2013, 07:46 PM
Banned
you know your stuff, but did you lap the valves at all.
Old 06-19-2013, 07:56 PM
WICruiser's Avatar
Not to be a smart a but is t possible the cam timing is off? The points are run off the cam so check the static ignition timing of the points compared to the spark timing mark on the flywheel.
Old 06-19-2013, 08:30 PM
LATECH's Avatar
Sounds like bad new chinese coil or condenser.
Fact is stranger than Fiction
Old 06-19-2013, 09:01 PM
i don't lap valves. I have thounds of dollars in valve equipment so I don't lap, grind only, 45 degree and 44.5 degree= instant seat.
Thing has great compression.. Thanks tho..
Old 06-19-2013, 09:03 PM
Checked it.. twice.. was my first thought.. thanks.
Old 06-19-2013, 09:06 PM
aaah soo but it has a nos USA coil on it. I will check condensor but has great spark.. Thanks..
Old 06-19-2013, 09:36 PM
LATECH's Avatar
Hmmmm. Then must not be problem Oh honorable one
Is it possible the cam is ground wrong? Maybe you should degree it.Just a thought.
Old 06-19-2013, 09:37 PM
LATECH's Avatar
could the compression ratio be too high ?
Old 06-19-2013, 10:06 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Did you put a new shear key in it? I know that the smallest shear mark on the key can cause problems. Just a thought
Old 06-20-2013, 11:24 AM
cal1320's Avatar
Back to basics. Pull plug and verify TDC. Make a temp pointer and flywheel mark. Verify when spark occurs (continuity buzzer on points). Degree cam(you already made a pointer, not that much more trouble). Do the valves open and close when they should. If all that is correct, its to the carb (only runs on full choke is not enough fuel. Jets clean, float level correct, etc).
Old 06-20-2013, 12:20 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
"probRem"
Old 06-20-2013, 01:46 PM
66GMC's Avatar
I'm feeling a little sheepish about that last comment.
I didn't mean to be malicious, but racial stereotyping still isn't cool.
My apologies to anyone that may have been offended ...
Old 06-20-2013, 02:12 PM
thinwhiteduke's Avatar
Living In The Past
I'll hold hands with cal1320, on the "only runs on full choke - not enough fuel"
Duke
Old 06-20-2013, 05:14 PM
Hey, it's all in fun.
« 86 c10 | Tires? »
a/c problems TMACPRO Hotrodding Basics 2 04-22-2011 02:26 AM
C4 Third problems KA67_72 Transmission - Rearend 3 12-19-2006 11:20 AM
Lifter Problems/Head Problems lewisdanw Engine 4 04-16-2006 01:47 PM
Thanks for help/Still have Problems Sweet-34 Electrical 3 05-01-2004 05:28 AM
C4 problems ranger crazy Transmission - Rearend 6 03-19-2003 03:08 PM
