-   Garage - Tools (http://www.hotrodders.com/forum/garage-tools/)
-   -   Kolbalt 2 stage compressor questions... (http://www.hotrodders.com/forum/kolbalt-2-stage-compressor-questions-127815.html)
gottwake? 11-07-2007 10:51 PM
Any have this unit?
I have a kolbalt that i purchased a while ago and just now getting around to hooking it up and lost the manual. What is the correct wire and breaker make-up for this install? 22A draw but that inst the surge for the start-up is it? I was under the assumption that the start-up draw was a lot higher like an A/C unit.
Kampr 11-12-2007 11:46 AM
I saw this a few days ago but wasn't able to reply at that time. I have a Kobalt K7580v2 2 stage with the 22 amp moter and assume that it's the same one that you've got. I found my manual and it said to use a 40 amp breaker but I couldn't find the wire size. I don't remember who I asked but I think I was told that I could use a 10 guage wire if it was under 50'. Maybe an electrician will chime in but if not I'll climb up and see what wire size that I did use. I've had my compressor for a couple of years and it's doing great. Good luck with yours.
Danny
Houston54 11-13-2007 07:35 AM
I have the same compressor and used a double pole 40Amp breaker and used 10 awg wire. The compressor is like three feet from the breaker box.
