Kolbalt 2 stage compressor questions... - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-07-2007, 10:51 PM
Any have this unit?
I have a kolbalt that i purchased a while ago and just now getting around to hooking it up and lost the manual. What is the correct wire and breaker make-up for this install? 22A draw but that inst the surge for the start-up is it? I was under the assumption that the start-up draw was a lot higher like an A/C unit.
Old 11-12-2007, 11:46 AM
I saw this a few days ago but wasn't able to reply at that time. I have a Kobalt K7580v2 2 stage with the 22 amp moter and assume that it's the same one that you've got. I found my manual and it said to use a 40 amp breaker but I couldn't find the wire size. I don't remember who I asked but I think I was told that I could use a 10 guage wire if it was under 50'. Maybe an electrician will chime in but if not I'll climb up and see what wire size that I did use. I've had my compressor for a couple of years and it's doing great. Good luck with yours.
Danny
Old 11-13-2007, 07:35 AM
Houston54's Avatar
Last journal entry: 1954 Chevy Truck Project
I have the same compressor and used a double pole 40Amp breaker and used 10 awg wire. The compressor is like three feet from the breaker box.
Compressor - Single vs. Dual Stage cab Garage - Tools 28 09-06-2010 04:48 PM
Single stage and duel stage air compressor? DeathByGreaser Body - Exterior 24 10-19-2005 06:33 PM
single stage or used 2 stage? zimaad Garage - Tools 9 08-04-2005 08:19 PM
Which waterpump? Eagle1 Engine 5 08-06-2004 06:38 PM
bc/cc over single stage? Lay'nFrame Body - Exterior 1 06-04-2003 01:56 PM
