Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - kolbolt wire feed
Old 02-04-2010, 08:53 AM
sunsetdart sunsetdart is offline
Last journal entry: 50 Ply wagon
Do you have enough wheel pressure on the wire? There are 2 grooves on the wheel, if the wire is small, like .023 and you have the wire on the .035 groove, then there won't be enough tension to drive the wire. Check your tension wheel and what size wire and what groove the wire is in.
