You need to explain a little better, do you mean the motor will run when jumpered? Jumpered where, at the motor itself or the trigger? If the motor will run when power is applied from another power source but not when the trigger is pulled then check for a connection where the gun wiring plugs into the feeder unit. If no problem there unplug the gun and connect an ohm meter to the connectors on the gun then pull the trigger and check for continuity between the connectors. If it remains open then the problem is the trigger (common) or possibly a broken wire in the gun (not so common). If pulling the trigger closes the circuit then the problem is somewhere in the feeder circuitry, probably a simple relay problem (again a common problem). Tell us more about how it is/is not acting and what you are doing to check it, in all likelihood this is a simple problem with an easy solution.
