Kragens HVLP gun - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-20-2006, 11:02 AM
black66's Avatar
www.airriderz.com
Kragens HVLP gun
I was in Kragen today and they have a 4 pc HVLP guns set. It looks identical to HF purple setup. I took the Kragens guns apart and the needle, tip and body look identical to the HF 43430 gun. Any feedback on Kragens paint guns? Pro X One is the brand name.
Here is a link to the setup: http://www.partsamerica.com/ProductD...tnumber=390213
Dave
Old 05-20-2006, 12:02 PM
weirdbeard's Avatar
1976 Ranchero GT
Last journal entry: Almost time for the first drive!
I like the metal cups on those. Very cheap price. Buy them and let us know how they work!
Old 05-20-2006, 12:52 PM
I have that exact set only it was labeled as Vaper, I believe. Stay away from that unless you can get it for $20 or less. The mini gun actually worked well, as good as my Devilbiss SRI mini gun with a smaller fan.
The big guns, however, are worthless. Both of them had some type of sealant/glue on the threads of the fluid tip where it screws into the brass section of the gun body. The included wrench was no match for it. Luckily a friend had one that was made with stronger metal. When it finally broke the brass section broke lose from the gun body leaving the fluid tip still attached to it. I decided not to try the second gun because the atomization is so poor, they do a terrible job even as a primer gun. I think they recommend about 30 psi and I've tried up to 60 without any noticable improvements. You would be much better off with the Harborfreight gun that everyone likes.
On the metal cups, they are very thin and soft, installing and removing the cover for the cup while holding the gun body will cause the cup to bend right at the bottom where it screws onto the gun.
I wasted over $100 when I bought a set over a year ago.
PS, reading over it let me clarify the fluid tip/brass section. The fluid tip screws into the brass section, the brass section screws into the gun body just ahead of the black ring you see in the picture (behind the aircap).
Old 05-20-2006, 12:55 PM
black66's Avatar
www.airriderz.com
thanks
Thanks for the heads up gtc. I was seriously thinking about getting them.... Now I am not....
Dave
Old 05-20-2006, 01:30 PM
I have seen that exact same set (Vapor) with that very problem. That is why the fellow brought them over to my place, his wrench broke too and he came over to see if I could get this loose for him. To be fair here the wrench that comes with the 43430 is apt to break also, I broke both of mine the first time I disassembled the guns but they did not appear to have that sealer and once broken loose the first time they are no longer a problem. The cups are as previously described and I would much rather have the plastic cup that comes with the HF gun. Although I now have an IWATA and no longer use the HF gun except for primer I still like that 43430 and can recommend it for the price.
Old 05-20-2006, 02:24 PM
Black66, did you notice how the aircap compared to the HF purple gun? Were the holes the same size and have the same pattern? The aircap should have more of an effect on atomization that the needle or fluid tip.
Old 05-22-2006, 08:44 AM
great adventure's Avatar
get rid of these guns...
i swear-ed to do not buy like the above metioned spray guns
1. the black seal behind the nozzle bet hard and cracked..
2. bottom of the cup start cracking while the gun in the
showroom
3. the blue or purple color on the handle .. start coming off
ga
Martin Senour Tech Sheets? unstable Body - Exterior 42 03-12-2011 09:09 PM
More on Orange Peel KarKen Body - Exterior 36 03-22-2009 02:18 PM
one giant orange peel flamedfordbronco Body - Exterior 14 06-20-2007 09:04 PM
shooting clear vinvango73 Body - Exterior 3 10-28-2005 11:24 PM
Orange peel in the clear Montypierce Body - Exterior 13 03-06-2005 08:49 PM
