Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Krylon paint job (be kind)
Old 02-23-2011, 01:57 PM
AutoGear AutoGear is offline
Find an Astro paint gun; its a very reasonable copy of a Sata/Iwata (very high end pro guns).
Go to Napa and buy a gallon of black industrial implement paint and a half gallon of epoxy primer.
If you want a GM number; 8555 is for gloss black.
Fix the dings and dents.
Reduce the epoxy per instructions on the sheet and use it as a sealer (to prevent a mottled appearence and seal the bondo)
Spray your paint and enjoy. Now, you can buy a disposable paint mask from Napa as well (NOT a dust mask) Id still recommend painting OUT DOORS early in the morning after the dew burns off
