Krylon plastic paint. - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-14-2003, 02:28 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Post Krylon plastic paint.
I've noticed ads on TV for a new Krylon paint that is supposed to cover and stick to any plastic. Has anyone tried it? How about polyethelene? Vinyl? They have pretty good products so I am curious of this stuff really works.
Old 05-15-2003, 05:02 PM
horvath's Avatar
Acoustic Rock ... for real.
Last journal entry: About Fusible Links
Post
Looks like no ones tried it yet, bro'.
I've been into Krylon's stuff (as a graphic artist) since 1966 when they first came on the scene and I've always liked their acrylics.
I saw that commercial, too and was wondering the same. I'll bet it's great.
Alan Horvath
<a href="http://AlanHorvath.com/54chevy/" target="_blank">54 Chevy Pickup</a>
Old 05-15-2003, 07:06 PM
Wiki Edits: 21
Post
Thanx for the reply. Guess I'll buy a can this w.e. and blast a bunch of plastic and see.
Old 05-15-2003, 09:21 PM
horvath's Avatar
Post
Cool! Be sure and post your results/impressions.
Alan
Old 07-29-2003, 04:35 PM
did it work
Old 07-30-2003, 11:46 AM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Their paint works as good as they say it does. I used it on plastics, poly type. Valspar is the owner of the company and they make most of the paint solids for paint companies. I used their brand to paint my car with.
They also own House of Colors. Heres their web site.
http://www.valspar.com/val/index.jsp
Luv the smell of NITRO in the morning.
Old 08-04-2003, 03:06 PM
Jag Daddy's Avatar
British Style with USA Muscle
Bought some this weekend for my dash cap, going to paint it up and I'll let you know. I found it at Michael's
Regards
Mark
Old 08-08-2003, 05:37 PM
I used that stuff for painting my laptop (an older 233, and it needed some flames .. it works wonderfully, I can't even get the paint to chip by trying
Old 08-12-2003, 04:03 PM
Jag Daddy's Avatar
I just painted my dash cap last night, it does a great job. It does however seem to be a bit tricky to get a really even coat. It took 3 coats to get the spray lines to go away, but man it looks nice!
Regards
Mark
Old 08-12-2003, 04:31 PM
1BAD80's Avatar
Wiki Edits: 2
A clear coat would help even it out.
Old 08-16-2003, 05:10 AM
MI2600's Avatar
Member# 3287
This brings up a point that I'm reluctant to raise but.... I've never really understood the different plastic terms used, e.g. polyethelene, etc. Anybody?
Old 08-18-2003, 04:44 PM
pzatchok's Avatar
OddJob
Polyethylene is made from a ethylene base mainly long carbon chains from petrolium. Used in pop bottles and the like. Thats also why they sometimes have a funny taste. Its also part of the reason for that "new car smell" I don't beleive them old cars had that same smell when new.
Polypropolene is made from organic compounds using long chains of propial carbon molocules. Used in milk bottles and nylon cutting boards. Doesn't inpart any funny tastes. It also breaks down in the open air and sun far faster than the polyehtylenes.
Some is now made from suger carbons in corn and made to fall apart in a year or less of being in the sun.
I just got all this info from my brother. He's in collage to be a chemist. I'm not that smart.
Old 08-18-2003, 10:02 PM
robbysapien's Avatar
383nova76
tips
do any of you guys have tips on how you painted with krylon paint because when i did it it didnt work as good as it did for you and it came off in huge chips
Old 08-18-2003, 10:18 PM
drlindz's Avatar
My brother-in-law picked some up to paint the plastic fenders on his dirt bike. Stuff just peeled right off. We first thought that he did something wrong but after stripping the paint off and making absolutely certain that the surface was clean and oil free, the paint again peeled. He ended up buying some stuff for painting urethane bumpers. That worked like a charm. I took what he had left of the Krylon and painted my computer case with it, worked great. I have come to the conclusion that the Krylon just doesn't bond well to flexible plastic surfaces.
Old 08-24-2003, 07:21 AM
deuce_454's Avatar
getting a paint to stick on a thermoplastic compound like polyethylene, or polypropylene is very difficult, and i will bet money that the fenders on your bros dirt bike is self coloured polyethylene, and no paint will bond to it, on on plastics like polyvinylcloride, or Vinyl paint and dye will be able to penetrate and bond quite well, yoot computer is peopably made from a bi-blend plastic containing Polyvinylclorice (PVC), polycarbonate (PC, or lexan) and is a good base for paints
and pzatchok: your brother should either get a refund on his college tuition or you just didnt pay attention when he explained to you that polyethylene and polypropylene both are made from the gasses, ethylene (or ethene) and Propene (the suffix -ene, instead of -ane refers to a double bond, meaing that it is unsaturated) this bond used to polymerise a long carbon chain, depending on the process you can either get High density or low density polyethylene, that are respectively relatively stiff, or relatively flexible. (the lids and bases if tupperware are HD-PE and LD-PE respectively) but both plastics are FDA aproved for food use and will under NO sircumstances EVER leave any taste at-all. period!
other plastic types are also polymerised chains of chemicals containing carbon, hydrogen and a host of other elements like clorine, suffur, bromine and many more. the possibilities are endless and the properties are as different. and to add to the confusion they can be blended and mixed with other plastics and solids or fibres, as an example, nylon can have peoperties like fishing line if used by it self. and mixed with glass fibrers be as stiff and strong as aluminium, the frame of a Glock pistol is nylon with glass fibre filling for example
and my knowledge of plastics is limited to 4 semesters courses at university when i was studying to ge an engineer. and ive only scratched the surface..
