Kwik Lift? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-06-2004, 07:33 AM
bigbird's Avatar
Last journal entry: Blasting Cabinet
Kwik Lift?
Any body out there have a Kwik Lift? If you do, how do you like it and would you recommend a purchase?
I'm thinking of getting a lift and just can't decide if that's the way to go. I like the 4 posters and I certainly have the room and ceiling height, but since I'm on a budget for the car, I can't see spending $2000 plus for the lift instead of the car. I had a chance to crawl under a Kwik Lift at Back To The 50's in St. Paul and really liked it so I'm just checking it out with you guys.
Old 08-06-2004, 12:38 PM
I like the scissor-type ones (like http://www.asedeals.com/lifts2.html) that you can easily drive over, personally. Still not cheap, though.
2002 Silver Camaro SS Hardtop w/Ebony Int, M6 w/Hurst, 294 RWHP 311 TORQ (100% stock)
Product Manager for industrial quality hose reels
Old 08-09-2004, 02:13 PM
Dave E Shank's Avatar
HEY BIG: I have had a Kwik Lift for about three years. I really like it and it has been great to use to work on my car. I only have a two car garage and do not have the ceiling high enough for a two or four poster. They also take a lot of width and the Kwik Lift foot print is much smaller. For the money you cannot find a better deal and Danny at Kwik Lift is great to work with. If you have any other questions give me a shout.....DAVE
Old 08-11-2004, 09:13 AM
bigbird's Avatar
Thanks Dave. I've seen one up close and really liked it. I certainly have the room for any kind of post lift, but there's just something about the Kwik Lift I like.
Fred
Old 08-16-2004, 04:59 AM
awsum34's Avatar
getting the car on the lift is tuff when the car isn't running.
Old 08-18-2004, 10:32 PM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
Yeah but, this will work in a pinch:
Name:	a little tug.jpg
Old 08-19-2004, 03:30 PM
USA1's Avatar
Hey alittle1, Nice truck, what is it?
Old 08-19-2004, 03:40 PM
Wiki Edits: 647
1940 Ford Pickup with a '67 289 Cobra, C4 trans, 9 inch rear. Still in the buildup process, but coming along.
Name:	40 ford pu june 01 ed.jpg
Old 08-26-2004, 11:33 AM
I have been studying the various lifts too. I'm convinced the Kwiklift is a good choice for those without tall garages. The Kwiklift has no mechanical items that can break down like a scissor lift has. The middle area under the car is completely open and accessible. A scissor lift obstructs the middle area of the undercarriage. You can order a sliding tool tray. Try to get that with a scissor lift. You can jack up and remove the wheels on the Kwiklift, so that is not a limiting consideration. It is adjustable to fit your car/garage and is self storing. The scissor lift is self storing too except you have to seperately deal with the power pack. Weight limits are not a concern. The scissor lift has limits and the more weight you have to lift, the more $ you will have to pay. Finally, look on E-Bay for Kwiklifts compared to Scissor lifts. You will rarely find a Kwicklift listed but the others are a dime a dozen. That is rock solid proof the Kwiklift is the right thing to get. Besides they are cheaper than the rest. For most rodders $ speak loudly. Right?
Old 08-27-2004, 03:16 PM
Wiki Edits: 647
I built my own Kwik Lift for less than $500. It is fully adjustable from Austin to Lincoln in width. I have an I-beam that goes from ramp to ramp which allows me to use a small hydralic jack to lift at the wheel. I have a rolling pan tray for oil changes. It is very versatile, I use it for frame fabrication, mechanical and exhaust work.
Old 08-27-2004, 06:59 PM
cboy's Avatar
Last journal entry: Finished
Hey alittle1, why don't you post a pic or two of the lift you built. I have a K-Lift already but those who are looking for a lift might be interested in trying to do it themselves.
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod.
Old 08-29-2004, 03:51 PM
Wiki Edits: 647
Garage Lift Pictures
Sure, no problem. This is a workingman's lift, if you don't mind the clutter. The ramps are 3 inch heavy channel with16 inches wide 1/4 inch sheet and the lifting beam is 4 inch I beam. The folding legs are double channel welled and ground at center seam to look pretty. The front stationary boxes are 20 x 20 bases narrowing to 16 x 16 tops, this makes them virtually non-topable. I built in the stop guards and added a lifting loop to the front to make them easier to lift and move. The rear of the ramps have a pipe end on the beavertail which makes it easier to drive over and by putting an axle, a couple hard wheels and pins; I'm able to wheel them anywhere I want to. Pictures are in my Gallery have a look.
Sooo, what do you think?
Old 08-29-2004, 07:36 PM
cboy's Avatar
Whoa, I LIKE IT. I'll bet a number of forum members will be trying to duplicate that. If I didn't already have one, I'd give it a shot myself.
Oh, and I like the "Fords in the snow" shot from later in your gallery. Reminds me of the day early last spring when I took my 32 for a little spin over to see some friends. A surprise storm kicked up and by the time I got back home there were three inches of snow on the roads. Talk about squirrelly.
Dewey
Old 08-30-2004, 11:29 AM
bigbird's Avatar
The lift is awesome. Very impressed!!!!
I'll have to hunt around and see if I can find the materials around town. After seeing what you've done, I bet my son and I could put one together.
How long did it take you to build it?
Thanks for sharing.
Love the winter shots....looks just like home here in Wisconsin, doesn't it cboy!!!!
Old 08-30-2004, 04:57 PM
cboy's Avatar
Yeah...in September!!!!!!!!
