Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - L-31 compression ratio and piston type?
Old 12-21-2009, 12:10 AM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
Yes the pistons are hyper pistons. The factory compression ratio was 9.4:1. There should be no problem converting it over as you wish. I`d say you`ll land in the 385 and up horsepower range but this is just a guesstimate. At any rate your sure to like the results.
