Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - L-31 compression ratio and piston type?
Old 12-21-2009, 07:48 AM
ap72 ap72 is offline
Banned
sounds like you could hit it with a hone and put in some std. flat tops. I know budget may be tight, but $100 for pistons, and $50 for rings, with some work done to the heads and a cam swap would give you 400hp AND cost less than the edelbrock conversion.
Its a lot cheaper to swap pistons than heads and Vortecs with $100 of machine work and new springs can support 400hp with no problem.
