Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - L-31 compression ratio and piston type?
Old 12-21-2009, 09:05 AM
ap72 ap72 is offline
Banned
you can save some weight by going to aluminum heads, and the heads you have listed are decent heads, your route isn't the most cost effective way to 400hp though, I was just trying to help your bottom line.
As far as pump gas and Vortecs, flat tops and Vortecs are ran a LOT. anything larger than a 268XE cam seems to run just fine on premium. If you are going for high RPM power you could probably get by on 89 maybe even 87 depending on a lot of other factors.
It all depends on what route YOU want to take. I was just trying to show you a cheaper route to make the 400hp you are after.
