Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - L-82 Vette Engine
Old 10-24-2002, 10:53 PM
78 monte 78 monte is offline
E.T. divided by $ spent= Speed
Post
Hotrod mag Oct90 did a motor it was a stock 350 replacement motor with 7.8:1 compression,and stock 1.94/1.50 heads.With a Crane cam 216/228@050 454/480lift,750DP,Holley contender intake and 1 5/8 headers it putout 297HP and 355lb/ft.And another article with the same except ported heads,015 head gaskets,decked heads put out 336HP and something like 380lb/ft.
Try looking up "Goodwrench 350 Quest" in google Thats how I found the 336HP motor.
Also I think your motor has 881 casting 2.02s 8.5:1. I'd say with like a similar split proile cam a duel plane intake,Holley,and headers and duel you'll pull 300Horse.
