L-98 to L-31 engine swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-16-2011, 08:27 AM
99 S-10 4.3 to L-31 they have the same fuel injection system. thats the main reason I went with the L-31, for stock appearance. I am using a LT-4 hot cam & kit. Port matching the heads & intake. Will the mass air sensor & throttle body flow enough for this combination?
Old 01-31-2011, 09:58 AM
If you haven't gotten the information already, the short answer is yes. You might be able to squeeze more out of it with a better intake and carb, but there are people running bigger (not much bigger) cams than that one. Just make sure the heads can actually handle that lift.
Where I'm getting this knowledge is that I was doing a similar swap and had originally wanted to go stock EFI route but was convinced that the intake would not breathe at higher rpms. There's no doubt it's RPM-limited but it seems to be enough for a lot of guys that are running 218 224 duration cams.
Pretty sure you'll need a V8 computer for that, but you probably know that already.
Hope you get all the help you need
Old 01-31-2011, 05:07 PM
l-98 to l-31 swap
thanks for the information I have the original pcm that needs reprogrammed for the cam & gears any suggestion would be appreciated.
95 ford F-150 engine swap, Same Transmission fit new engine? F-150 Transmission - Rearend 5 10-07-2007 12:11 PM
86 K10 engine swap! swap tranny too? big_e111 Transmission - Rearend 3 08-03-2007 01:21 PM
Hello..need help deciding engine and or engine/tranny swap. suzukijohn Introduce Yourself 2 04-22-2007 09:35 PM
Engine Swap or Not opnsrc General Rodding Tech 2 07-17-2004 08:53 AM
326 firebird engine swap with a 400 engine...is it possible?? greg67 Engine 7 11-08-2003 03:34 AM
