L31 Vortec Conversion to Carb. - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-25-2010, 01:14 PM
Rodding & Camping-Love It !!
To convert an L31 Vortec to carburetor is it as simple as the correct intake w/carb. & distributor w/vac adv ? IF so what would be the base line timing for start up?
Thanks
Old 07-25-2010, 01:29 PM
I also just read this in the archives "if you have a roller cam that you will need to change out the distributor drive gear or you'll wreck stuff." Is this correct? The L31 has a roller cam. Sometimes you wonder IF maybe we read to much????
Thanks
Old 07-25-2010, 01:51 PM
Sinister's Avatar
You'll need a melonized distributor gear. You'll have to figure out a fuel pump as well.
Old 07-25-2010, 01:55 PM
Well I guess I'm REALLY going to show my age or lack of knowledge at this point!!! Im clueless as to what a Melonized Gear is. Can you bring me up to speed??
406cu.in. of tire smokin' fun
Last journal entry: 406 Build Thread
You already have the correct distributor gear, but I would replace it with a new one anyway as cheap insurance. I found out the hard way and got to rebuild the engine a second time. Saving $40 cost me about $800.
The fuel pump should work fine, but you'll need a regulator and will need to wire it so it comes on with the ignition.
Old 07-25-2010, 02:01 PM
The Dist. that I have is a "New" Crossfire HEI so would I assume that the gear would be OK? I know its new as I just bought it as a back up for the 33 Chevy.
I also "plan" on pulling the in tank pump and going with the original block mount pump or a good electric frame mount pump. First I must determine if there is a fuel pump lobe on the cam!!!! I've been lead to believe that some ZZ4 cams do not have a fuel pump lobe????
Old 07-25-2010, 02:10 PM
techinspector1's Avatar
Wiki Edits: 326
Originally Posted by Ct Street Rod
To convert an L31 Vortec to carburetor is it as simple as the correct intake w/carb. & distributor w/vac adv ? IF so what would be the base line timing for start up? Thanks
Yep, pretty much. You'll need an electric fuel pump and filter and make sure not to exceed the pressure limit of the carburetor you'll be using. 5 1/2 lbs max for a Quadrajet, AFB or Performer. 6 1/2 lbs max for a Holley. This is not a case like EFI, where more pressure could make more horsepower. With a carb, you have to limit the pressure into the bowl to prevent over-powering the needle/seat and blowing raw fuel into the intake manifold. Set the float(s) properly and limit the pressure. Electric pumps work best when the push, not pull, so mounting the pump/filter back at the tank/cell is a good idea. That is also a good place to mount a regulator. Use one that will dump excess fuel back into the tank/cell rather than a deadhead regulator that will heat the fuel and wear out the pump quicker.
The blurb about distributor gears probably should have been worded differently, like....."Insure that the material that the distributor drive gear is made from is compatible with the material the camshaft drive gear is made from". The camshaft drive gear is normally part of the casting of the camshaft, so you would want to touch base with the tech at the cam grinder to find out what they like for distributor drive gear material compatibility with that particular camshaft.
With L31 heads, I would start at 34 degrees initial + mechanical, all in by 2800. More cam will want more initial ignition timing, so increase the initial and limit the mechanical to get to your 34. Once the motor is running, you can try rocking the timing back and forth a couple of degrees, but the L31 chambers are very efficient and should work best around 34.
The following is quoted from www.gnetworks.com and says it best about the ignition timing with a larger cam.....
"INITIAL TIMING
The chief function of initial timing is to provide a clean idle
and crisp throttle response. One of the best guides to
determine the initial ignition timing of V8 engines can be
found in the Barry Grant, Inc. catalog or at their website
under the Demon Carburetor Guide. Typically, they recommend 10- to 12-degrees of initial timing when
the duration of the camshaft is less than 220-degrees @ 0.050 of valve lift; 14- to 16-degrees of initial
timing with a camshaft duration of less than 240-degrees @ 0.050; and 18- to 20-degrees of initial timing
when the camshaft duration is less than 260-degrees @ 0.050 of valve lift."
Old 07-25-2010, 02:12 PM
Sinister's Avatar
In addition to the fuel pump lobe, the block might not be machined for a mechanical fuel pump. As for the distributor gear: http://www.summitracing.com/parts/ACF-10456413/
Old 07-25-2010, 02:19 PM
The block is machined, it does not have a pump rod as of now. Plan on putting a rod in and hand turn the motor over to see if it pumps.
Thanks to all you guys for sharing your knowledge. Any firearms questions
Old 07-25-2010, 05:30 PM
Wiki Edits: 326
............Never mind. Unrelated to the subject.
Old 07-25-2010, 07:21 PM
I hesitated to add that at the end BUT I am grateful to you guys for sharing your expertise and was throwing that out as a gesture for my expertise. I really should have said to send PM.
98 350 vortec conversion 98Disco1 Electrical 3 01-17-2010 06:58 PM
1997 5.7 Vortec Conversion 71ChevySWB Engine 2 01-14-2003 08:42 PM
Vortec Conversion For Small Block Chevy M-1-4 Engine 3 11-20-2002 06:51 PM
TBI conversion to Carb Seon Engine 0 10-15-2002 04:20 PM
4.3L vortec conversion fightingcody Engine 3 05-18-2002 10:41 PM
