L48 engine and head swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-05-2009, 04:24 PM
I have a 1977 L 48 corvette engine that I am rebuilding and I am thinking about adding some used vortec heads and manifold from a salvage yard after a conditioning. What casting number should I be looking for and normally what engine would I find them on. Also will most of them be able to be used on a Gen 1 block without modification. I know that there is a casting number that is generally not a good one. I also understand that they are normally on Chevy trucks. Thanks for any advice.
Old 07-05-2009, 08:24 PM
DoubleVision's Avatar
You`ll be looking for 062 and 906 Casting numbers. They came on 1996 and up 350`s that were in C1500 and C2500 pickups. There isn`t a "bad" vortec casting number except for the 305 vortec head. If you find some in the yard, find out if you can return them if they are cracked. Take them to a machinist and have them magnafluxed to be sure they are crack free. If you plan to run a carb then you`ll need a aftermarket intake that will bolt up to the vortecs. Make sure you keep the rocker arms that are on the heads as they are self aligning, you`ll need them unless you plan to use guide plates. No other mods are needed to run these heads on a older SBC.
crate chevy 302? Vancouver Grand Prix Hotrodders' Lounge 106 12-31-2012 05:05 PM
1968-1969 olds 455 engine is this good and how can i id 1968olds455HO Engine 5 09-02-2009 12:53 PM
Valve Lash adjustment hiball Engine 36 05-11-2009 11:12 AM
302 chevy engine mess NaythanOldskool Engine 17 12-18-2008 01:04 AM
Cam Help black66 Engine 3 05-12-2003 07:15 PM
