Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - l98 heads?
Thread: l98 heads?
Old 07-04-2009, 12:01 AM
TANGO TANGO is offline
Originally Posted by TANGO
I used a Set of them #083 TPI Heads on this 350 Build . They are 64cc Chambers with 1.94"in and 1.50"ex Valves . Pre-Vortec Performance Heads . I would say they are good Street Heads for a 350 350 H.P Build .
Thanks for that info, I might buy a set off an 87 iroc.
will they bolt up to my gen1 350 intake?
that motor sounds mean.
After you elongate the 4 Center Holes on the Gen 1 Intake to match the 72-degree angle that the Heads are Tapped at it will bolt Right one . Yes I had to do that with my 350 Build . I used an Early Edelbrock #2101
