Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - L98 heads and dome pistons
Old 10-17-2012, 01:23 PM
ardmsrt ardmsrt is offline
Hello Rod Buddies. Well, here is my first post. I want to see if this is possible on hot motor build sbc 4" bore. Plan on running 480 lift solid cam and 110 petro and 3600-4200 stahl. Would like to use L98 aluminum heads (10088113) on my sbc with Wiseco dome pistons. .035 mls gasket and 3" stroke. Setting the head on I see the dome pushes against the structual rib that's by the spark plug hole inside. Can I grind the rib down for clearance and not worry about structural damage to the head. I have cast heads also, 375 F.I. and also 882's that will probably fit fine. I think I know I'll have high compression motor but don't know exactly how high. I've never used an aluminum head and would like to try this set-up if it's possible. Any help would be greatly appreciated.
