Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - L98 heads and dome pistons
Old 10-17-2012, 10:09 PM
hcompton's Avatar
hcompton hcompton is offline
Old & Furious
I dont think he can pick a cam since the heads dont fit the block. He is going to end up with diff heads or pistons before its right. At the very least he will need the compression ratio. If it super high those small cams will be more trouble than the lack of hp is worth. If you get my meaning.
The Following User Says Thank You to hcompton For This Useful Post:
ardmsrt (10-17-2012)
