lack of horses - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-04-2004, 09:08 PM
Question lack of horses
I have a 74 chevy 1/2 ton w/350 4bolt. This is the original motor, when Igot the truck the cam was completly rounded. I have changed the cam,intake manifold,carb,&dist.This motor came with a 2bbl and this what was replced with. When you go to take off the motor tries to cut out but if u feather the gas pedal it comes back around but with serious lack of power. I know this motor is strong a friend has same setup and running fine. PLEASE HELP!!
Old 03-04-2004, 09:12 PM
lluciano77's Avatar
It sounds like your accelerator pump shot is weak. Give it more gas on the accelerator shot.
You may need a different power valve as well. When you add a performance cam your vacuum changes, and so does the powervalve opening requirement.
Old 03-04-2004, 09:15 PM
FASTCHEVY's Avatar
RatRod B4 RatRods were Cool
Could be a timing prob.
What have you replaced on the truck?
Power valve? how do you know he has a Holly?
We need more info.
Old 03-04-2004, 09:39 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
Who said anything about it being a Holley?
Old 03-05-2004, 12:24 AM
4 Jaw Chuck's Avatar
Sounds like the thing needs some TLC and an overhaul...start with the carb.
— Han Solo
Old 03-05-2004, 12:44 PM
funk master flex's Avatar
how do you know holly
Old 03-05-2004, 02:00 PM
Muscle car fan
carb and or timing
did you get rid of the EGR when you got your new manifold?
may need to re-curve your distributor
why are you jumping all over the "how do you know he has a holley" stuff people? this is supposed to be a friendly board
'74 Gran Torino Project
351W, c6 trans, 9"
Old 03-07-2004, 09:25 PM
Yes it's a Holly. It's a 2BBL on a 4BBL manifold. The distributor has been completely rebuilt. The EGR valve is gone. New timing chain and sprocket. Timing is dead on at 8 degree. Using an abundant amount of gas. Occasionally backfires through the carburetor. This is a stock 32K V coil, would it help to go to a higher voltage coil, possibly not enough spark?
