Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - lacqer primer over sealer primer
Old 08-21-2008, 03:16 PM
oldred oldred is offline
Originally Posted by jake henderson
Is it ok to spray lacquer primer over sealer primer?
I just want to know if it is Ok?
Thanks
It's not OK to spray lacquer primer over anything! Why are you using lacquer primer? That stuff is junk and will cause nothing but problems, it and the lacquer based 1k spot putty are both a recipe for disaster because both will continue to shrink for weeks or even months causing all kinds of problems. Even the economy 2k primers are far better than lacquer and since you will not need to use nearly as much of the 2k it will be cheaper too!
