Shine I don't think he was asking about using lacquer paint he is wanting to use lacquer primer.
Lacquer primer is a disaster in the making so if anyone wants to believe it wont shrink and ruin your paint go ahead and use it find out the hard way. The problems associated with using lacquer primer are well known and to insist it will not shrink anymore after a few minutes drying time is just simply ridiculous. Also buying $40 a gallon primer says volumes about the quality of a persons work and you can believe it or not but the cheaper 2k primers will cost less to use because that lacquer junk takes 2 to 3 times as much to do the same job!
