Ladder Bar Install - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-29-2006, 04:20 PM
Ladder Bar Install
I have a 66 fairlane I would like to put 33" ladder bars with coil over springs on it. Can anyone tell me how to install this? Thanks alot
Old 10-29-2006, 07:04 PM
66 fairlane rr susp
Hello, I just happen to be restoring a 66 or 67 fairelane ranchero at work.
Assuming the rear suspension is the same I'll have a look at it in the next few days to see if I can help. Bye4now
Old 11-07-2006, 03:11 PM
Ladder bars
Go to Art Morrisons web site. They have some tech articles there I think that may help you. It's pretty straight forward. Now a 4 link is a different story! Hope this helps.
Old 11-07-2006, 03:54 PM
If this is ment to be a driver... I would use a more traditional style four bar suspension. Ladder bars tend to bind the rear end virtually eliminating any axle articulation.
Old 11-11-2006, 01:10 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Ladders on a leaf car require that the leaves be mounted in a slider to prevent vertical suspension bind. Any ladder set up binds any rear end during body roll since everything is mounted solid.
I suggest Cal Track bars as a better solution.
Old 11-12-2006, 02:27 PM
Latter bars are pretty straight forward to install. Just make sure thats what you really want. Make sure you know the pros and cons.
Old 11-18-2006, 01:24 PM
xntrik's Avatar
If you are going to use coil overs on the Fairlane the upper shock mounting point is not strong enough to hold the vehicle weight. You will have to make a mount to hold the upper end of the coil overs.
I would look into the Wonder Bar rear end that Fatman is offering for the Mustangs (same as yours). See the upper coil over mount he is using and go from there.
Actually that Fatman suspension would be very good in the Fairlane. We were using it back in the middle 60s with quarter elipticals.
Roll Bar Install Advice Mustangsaly General Rodding Tech 12 12-02-2007 08:33 AM
Best darn ladder you will ever use. MARTINSR Off-Topic 11 03-31-2006 08:21 PM
Ladder bar install Knobie Suspension - Brakes - Steering 2 10-18-2004 12:23 AM
Ladder Bar Rear Axle Centering gilesletheren Suspension - Brakes - Steering 6 05-18-2004 11:05 AM
Ladder bar suspension install question glock35ipsc Suspension - Brakes - Steering 6 07-17-2003 10:46 AM
