Ladder bar preload w/coilover how to set - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-15-2012, 05:08 PM
I have installed ladderlink bars and coilover shocks on my 73 nova with 9" ford rear end. rear axle is plumb and square and pinion angle is about 2.5 to 3 degrees negative how do i set preload?
Old 05-15-2012, 11:37 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
preload
most people scale the car with the driver in it. so you have equal weight on the tires.
Ladder Bar Install 429CobraJet Suspension - Brakes - Steering 6 11-18-2006 02:24 PM
Ladder bar setup 102221 Suspension - Brakes - Steering 1 10-11-2006 06:32 PM
Using Wheel Scales To Set Preload BillyShope Suspension - Brakes - Steering 8 04-20-2004 07:35 AM
ladder bar plans? 70chevelle327 Suspension - Brakes - Steering 5 03-03-2004 10:30 AM
LADDER BAR BACKHALF Help Pro1972nova Transmission - Rearend 5 01-03-2003 07:06 AM
