Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - ladder bar tuning
Old 02-28-2003, 06:32 PM
TurboS10's Avatar
TurboS10 TurboS10 is offline
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Post
Ladder bars are for the most part unadjustable. I believe the adjustors are just to set pinion angle. There is not alot you can do to get the front end in the air if it will not do it now. On ladder bars the instant center is where the front of the bars attatches. If you have multiple holes in this mounting point you may have a little bit of adjustment. If that is the case, the lowest hole should give you the most lift.
chris
[ February 28, 2003: Message edited by: TurboS10 ]</p>
