Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - ladder bar tuning
Old 03-03-2003, 07:15 AM
willys36@aol.com's Avatar
willys36@aol.com willys36@aol.com is offline
Wiki Edits: 21
Post
As previous posts point out, there are a lot of considerations in getting your nose off the ground. it isn't all hp or weight transfer, etc., rather it is the entire system. The thread below discusses this tropic in detail. I posted some basic equations which should get you into the ballpark of the setup you need. In summary, you need enough torque, enough weight on the rear tires, enough traction, and center of gravity far enough back or you can't get off the ground.
<a href="http://www.hotrodders.com/cgibin/ubb/ultimatebb.cgi?ubb=get_topic&f=15&t=004682" target="_blank">http://www.hotrodders.com/cgibin/ubb/ultimatebb.cgi?ubb=get_topic&f=15&t=004682</a>
