Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - ladder bar tuning
  #23 (permalink)
Old 03-11-2003, 03:18 PM
TurboS10's Avatar
TurboS10 TurboS10 is offline
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Post
[quote]Originally posted by strawntech:
<strong>ok guys we will turn the spring nuts up they are very low right now
thanks</strong><hr></blockquote>
Most Coil over shocks have a recommended ride hieght. It is usually recommended that they be right in the middle of the stroke. Be sure you dont get so far up you have problems with topping out. If you have to set the shocks in the top 2/3 of the stroke, it might be a good idea to get some stiffer springs.
Chris
