ladder bars on a 4wd - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-18-2007, 01:26 PM
hello all I have a question about a 4wd. I am having a extremely hard time finding a lift kit for my 64 IH Scout 80. I only want to get an extra 4 inches to clear some meatier tires. I have thought about going with an adjustible coil over shock and can't decide which would be better a 4 link or a ladder bar set up. Also, do I mount the front 4 link or ladder bar to the front of the axle or run it back towards the center of the truck? Any help will be greatly apprciated. Also how short can I get the ladder bars if i need to run the front forward?
Old 04-19-2007, 09:41 AM
bet on black's Avatar
hotrodder 4 life
i would run them towards the center of the truck so you can run a longer bar, resulting in less pinion angle change during travel. also, i think the frame would be stronger and less prone to flexing at the mounting points in the center as opposed to mounting them at the front of the frame
ladder bars would be easier, 4-link would be better, imho
Old 04-19-2007, 10:02 AM
it is a short wheel base 4 wd so im not really looking for ride quality. plus it isnt gonna be a daily driver. It will mainly get driven to the woods or nearest mud hole and played with. And to the IH shows that are around the house.
Old 04-19-2007, 10:26 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Because of the conditions of 4 wheeling we do not use ladder bars on those..either the 4 link or a truck arm type suspension. On the truck arm we use a monoball mount located just under the front u-joint..this allows us to lift the truck substanially and get the travel and rotation of the axle needed in a 4by..A panhard bar is also required on these or maybe a watts link to locate the rear axle..
Sam
Old 04-19-2007, 10:36 AM
what is a truck arm suspension??? never heard of that.
thanks for the input
Old 04-19-2007, 11:53 AM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
Truck arm suspension is named after the trailing arm rear suspension system used by GM on 1960-72 pickiups.
Here is a link to a home built one.
Home-made truck arm suspension
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old 04-20-2007, 06:27 AM
Look at a Range Rover. Great travel,great ride and cheap as dirt in the wrecking yards. The suspension gets swapped into all kinda 4WDs here.
Track should be similar too.
ladder bars in my chevelle dk01_99 Suspension - Brakes - Steering 15 04-08-2013 07:24 PM
Best darn ladder you will ever use. MARTINSR Off-Topic 11 03-31-2006 08:21 PM
Ladder Bars fred56 Suspension - Brakes - Steering 4 08-06-2005 10:53 AM
Traction Bars or Ladder bars JamesRS Transmission - Rearend 1 07-19-2005 05:57 PM
parallel leafs, or ladder bars & coil-overs? sandman351 Suspension - Brakes - Steering 1 08-28-2004 08:33 AM
