ladder bars in my chevelle - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-11-2004, 02:19 PM
ok well i have some ladder bars i will be putting in my chevelle when the body and some actual weight is back on the car. but my question is do you keep the upper control arms when you go to ladder bars? i was recently told that the lowers have got to go so now i can't use my sway bar for this also. does a panhard bar act like a swaybar or what? competition engineering recommends using a panhard bar upon installment of their ladder bars. any info on this would be great! i tried searching on here but got didnt retrieve up any info. see ya
Old 05-11-2004, 02:29 PM
A panhard rod keeps the rearend from moving in a sideways motion.
It will not act like a sway bar.
A problem with panhard rods is that if they are not long enough you will get a side load on the rearend and ladder bars as the vehicle moves through it's vertical travel.
Old 05-11-2004, 05:01 PM
brainsboy's Avatar
brains
interesting enough I have a set of aftermarket lower control arms I dont need now, they are for a chevelle
Old 05-12-2004, 05:27 AM
BillyShope's Avatar
Philippines Cowboy
Last journal entry: THE TRACTION DYNO
This looks to me like a much better route than the ladder bars:
http://www.employees.org/~redneck/carstuff/rear.htm
Old 05-12-2004, 02:05 PM
brainsboy- thanks for the offer (?) but i already have boxed lower control arms and since i will be eliminating them then i wont need another pair .
billyshope- all he has is the stock setup with airbags and an added sway bar. im going for more of the straight line route and thought it would be best if i went with ladder bars other other than traction bars or an all out 4 link setup. thanks for the link though.
Old 05-12-2004, 05:45 PM
what is your intended use of the vehicle if you have boxed in your control arms i would just replace the bushings and use them that way unless it is an all out drag car i wouldn't go with the ladder bars. and for the street you would be better off with the four link you have now eich is what the stock is.
Jesse
Old 05-12-2004, 07:06 PM
well iam planning on hitting up the strip quite a bit but i also want to drive it on the street also. im hoping to see 10's when all is said and done with the motor though, thats why i thought i should go with ladder bars.
Old 05-13-2004, 05:42 PM
1950bulletnose's Avatar
Last journal entry: Left Concave Rocker
Ladder bars are no good for the street. They are designed for straight line as in drag racing.
Trust me I went that route and found out the hard way.
I've now built a new frame and went with a tri-angulated 4 link and air ride. You on the other hand can use coil-over shocks. No need for an anti-sway or panhard bar with this setup.
http://www.angelfire.com/super/1950b...ular4Link1.jpg
http://www.angelfire.com/super/1950b...ular4Link2.jpg
http://www.angelfire.com/super/1950b...Shockwave3.jpg
http://www.angelfire.com/super/1950b...NewFrame16.jpg
http://www.angelfire.com/super/1950b...irbagsIFS1.jpg
Old 05-14-2004, 12:30 AM
why are the ladder bars no good for street use? and why would i only need to run the coil overs? everything will still be able to twist at launch still right? as compared to using a sway bar to help with that.
Old 05-14-2004, 02:34 AM
Ladder bars don't allow for roll. They will only travel up and down. As you can guess this would make them no fun on the street.
Think of it this way...
When you take a right hand turn the body wants to roll to the left. This causes the left ladder bar mount to want to go down and the right ladder bar mount up. This tries to twist the axle tube and in essance turns the axle tube into "one really huge sway-bar!". Obviously the axle tubes arn't going to twist (till you shear the plug welds holding them into the axle housing ) and what you end up with is a car that can't roll. If you hit a pot hole with just one tire it will transmit the force through the axle and to the body and will cause a very jaring ride on anything that isn't smooth.
Old 05-14-2004, 10:22 AM
With coil-overs you don't need anything else. Also coil-overs give better launch characteristics.
Again ladder bars are for drag racing only and if someone told you different, you're in for a costly mistake. I know, I went that route and it cost me. I'm now selling the ladder bars and coil-overs to recoupe some of my loss.
Ladder bars use a lateral bar as opposed to a panhard bar. Attached pic of my old setup.
http://www.angelfire.com/super/1950b.../stude1015.jpg
http://www.angelfire.com/super/1950b.../stude1016.jpg
A Tri 4 link and a parallel 4 link are the only ways to go for a street application. I don't think a tri 4 link would be any good on the strip, I'd go with a parallel 4 link if you're thinking of the pro street approach.
Old 05-14-2004, 10:48 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Ladder bars are great for street cars if installed correctly. They can be made to work with any type of spring; leaf, coil, 1/4 elliptic, etc. Send me your email address and I'll send an article on how to mount them for max suspension flexibility.
Old 05-14-2004, 12:57 PM
willys36, you've got a pm.
i understand that with ladder bars on the street it can be a very rough ride but is this the only downside?
Old 04-08-2013, 01:09 PM
Would you send me the info on ladder bars? I want to install them on a 1971 chevelle
Bluemagic920@cox.net
Old 04-08-2013, 07:10 PM
RWENUTS's Avatar
Did you notice this thread is 9 years old and the last time the op was here was 8 years ago.
You got a question start a new thread!!
