Ladder bars or what ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-25-2007, 06:17 AM
I was here someplace yesterday, The discussion was on ladder bars and a tube welded to the rear end. The welded tube was shaped like a hockey stick the blade end was welded to the rear end andthe other end was bolted to the frame which made a pivot point. There were pictures of someones project also.
Does anyone know or seen this info I am trying to discribe ?
Old 02-25-2007, 06:59 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Use the search function on this site...type in ladderbars or traction bars, whatever and see if you can find it. OK...I just did a search for ladder bars....click here to see what I got... scroll the whole page. http://www.hotrodders.com/forum/sear...earchid=890406
Old 02-25-2007, 07:42 AM
ladder bars
Thnx , I did the search before and read for an hour or so but couldn't find the same post I was at yesterday. Not yet anyways.
Thanx again
Old 02-25-2007, 09:37 AM
joe k's Avatar
With out seeing the post you're talking about I'm going to guess you're describing a panhard bar. Try Speedwaymotors.com part#916-45504 and see if thats what you're talking about.
Old 02-25-2007, 10:07 AM
panhard bar
Thanks Joe
Old 02-25-2007, 10:18 AM
powerrodsmike's Avatar
Wiki Edits: 161
If you check your browser "history" of the pages you visited yesterday at HR.com you could look through them and see which posts you looked at. (it all depends on how you have your internet settings, if you don't keep a history,then you are SOL.)
That's how I do it when I can't remember where a page is that I didn't bookmark.
Later, mikey
BE different....ACT normal.
Old 03-02-2007, 05:47 PM
Larry3's Avatar
Bottom of the page
While I was reading your question and the replies, on that same page at the bottom (scroll) was a list of similar threads that might help.
Larry3
ladder bars in my chevelle dk01_99 Suspension - Brakes - Steering 15 04-08-2013 07:24 PM
Best darn ladder you will ever use. MARTINSR Off-Topic 11 03-31-2006 08:21 PM
Ladder Bars fred56 Suspension - Brakes - Steering 4 08-06-2005 10:53 AM
Traction Bars or Ladder bars JamesRS Transmission - Rearend 1 07-19-2005 05:57 PM
parallel leafs, or ladder bars & coil-overs? sandman351 Suspension - Brakes - Steering 1 08-28-2004 08:33 AM
