lag or lack of power
hi everyone
i'll get straight to it.. i'm working on a 350 and am having trouble with a lag off idle and really a lack of power..... i recently installed a 292H magnum .501 lift cam,rpm air gap intake magnum roller tip rockers,pushrods guide plates,new springs decked the heads 650 double pumper carb,...i"m having a heck of a time trying to get it to perform..timing marks are way out to lunch so i tried power timing it. it got a little better but its still acting like its retarded and labouring!!!anyone have any suggestions?would appreciate some tips thx! |
Timing 36 degrees all in @ 2500 rpm that should pick it up . Other tweaking, carb tuning and possibly jetting will refine it .
For instance, say your curve is such that your timing reaches its maximum advance at 2500 rpm. While holding the engine at the 2500 rpm adjust your timing too 36 degrees and lock it down . If it pings back it down 2 degrees, SBCs typically love 34-36 total ... mine likes 36 . Last edited by pepi; 06-15-2010 at 09:23 PM. |
You better have some compression. And a low-ish rear gear unless the vehicle is very light weight. Knowing the details of the engine build will help.
timing
is there a possibility i need to degree the cam?
ok thx.. i will check things out tommorrow
| acceleration flat spot in carb. | corvettetonybone | Engine | 17 | 04-13-2013 08:31 PM |
| Can Holley Power Valves stick shut? | Argess | Engine | 2 | 09-01-2009 10:02 AM |
| How Does This Stuff Work? | docvette | Electrical | 3 | 06-18-2006 03:00 AM |
| Advise on Porta Power choice | meanroy | Body - Exterior | 7 | 06-23-2004 11:38 PM |
| Unusual Power Steering Conversion | Lars Sorensen | Suspension - Brakes - Steering | 17 | 05-25-2004 02:05 PM |
