Lake Dexcool - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-21-2007, 12:58 PM
T-bucket23's Avatar
Wiki Edits: 26
Lake Dexcool
This is what happens with DExcool and inferior gaskets. These pics are of a 4.3 in a 2003 blazer with 60K miles.
it was full right to the top. Drained 3 Gallons of coolant out of the oil drain before the oil came out.
ID:	23610   Click image for larger version
Old 08-21-2007, 01:13 PM
DoubleVision's Avatar
Allrighty then, grab the server spoon, bring your cups and let`s drink up.
That sure don`t look good, I can only imagine what the rest of it looks like.
My fathers truck is a 98 GMC Sierra with the 4.3 Vortec, it has 152,000 miles and the gaskets are still holding so far. When I bought my Vortec 350, the intake gaskets was the reason he had it for sale. When they blew he removed it since it had high mileage and swapped over to the replacement engine he already had for it.
Old 08-21-2007, 01:17 PM
The reason I don't run Dexcool in anything. The stuff is quirky, the smallest amount of air gets to it and you've got big problems.
Bogie
Old 08-21-2007, 09:58 PM
GM Tech
Yeah, I try and convince people to flush the dex-cool out of their vehicles and run the good old green stuff. I've pulled heads off vehicles with 40-60000km on them for various reasons...trucks especially to remove broken exhaust bolts...and the head gaskets look horrible! They are eroding, crumbling, and swelling around all the coolant passages! Don't believe the factory claims of 250000km service intervals! The crap gets extremely acidic! It destroys gaskets. It's also expensive and it stinks! But it looks like Tang!
Old 08-21-2007, 11:26 PM
Looks like pesto sauce.
Old 08-22-2007, 12:33 AM
We swapped over to plain green anti-freeze in my fathers pick up years ago, it`s likely the reason it hasn`t eaten the intake gaskets. I`ve heard some say it`s not the dexcools fault and others that say it is. Me? I didn`t want to take any chances, I sure didn`t want to have to remove that mess from the top of that 4.3 Vortec either, hence the reason for swapping. Hard to believe it made it that far, as the truck already had over 115,000 miles on it when we did the switch. In my 92 chevy pickup, I use regular anti-freeze about 30%, and water at 70% as here in the south it doesn`t get really cold. I also use a bottle of red line water wetter.
Old 08-22-2007, 12:42 AM
YuK i can forsee that 4.3 spinning a bearing.........Those vortecs are notorious for leaking intake gaskets.....fel-pro makes a problem solver gasket for the small block vortecs not sure if they make one for the 4.3 or not.
Old 08-22-2007, 10:58 AM
T-bucket23's Avatar
Wiki Edits: 26
We didn't fix it, we told the customer we would but no guarantee it would hold together.
He paid us for taking it apart and towed it away. He is going to get a junk yard engine and swap it himself.
I would like to get a movie of that. Those blazers a re a real pain in the butt to swap an engine in.
Old 08-22-2007, 12:48 PM
scapegoat's Avatar
Iv'e got a 2000 gmc jimmy with the 4.3 with 73000 miles on it. Can I flush that dexcool out and put regular green antifreeze in it? I have heard to many horor stories about it to even want it in my jimmy. My buddy goes throught intake gaskets like its going out of style on his 4.3.
Old 08-23-2007, 05:44 PM
T-bucket23's Avatar
Wiki Edits: 26
You can but you have to get it all out, pull the block drains on both sides and run water through it until it comes out clear. Run it until the stat opens and do it again. You have to get all the dexcool out. Just doing the dump the radiator and run a hose through it for a while isnt going to do it. You have to drain the block
Old 08-23-2007, 10:18 PM
MI2600's Avatar
Member# 3287
If you want a real horror story, Google Dexcool.
After reading that and GM's multiple excuses for Dexcool failures, I flushed my daily driver, '98 Monte Carlo, with both a long-term and short-term flush and went with the green.
Old 08-23-2007, 10:40 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Yes they do.
Part Number: MS-98002T
I just replaced them on my daughter's 2000 Silverado 4.3.
I have heard the Dexcool stories before, and have swapped it over to "green stuff" in my 98 Grand Prix GTP.
49 Merc Lake Pipes croddc5 Body - Exterior 1 11-04-2006 08:02 PM
Question about triple lake pipes??? workingclass Engine 2 03-26-2006 09:49 AM
lake george pics are up IROC100 Hotrodders' Lounge 5 09-22-2005 06:38 PM
Lake/ side pipe question Magnus_Jager Body - Exterior 7 02-16-2005 03:29 PM
Anybody from Lake Tahoe dano_711 Hotrodders' Lounge 2 09-15-2003 05:16 AM
