lake style headers for a 292 Y-block? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-06-2005, 09:46 PM
mercflathead's Avatar
FLATHEAD FOR LIFE
I want lake style headers for my 292 Y-block, but i have not found any on the net i've been to every Y-block website i can find.
Pat
Old 04-07-2005, 09:54 AM
willys36@aol.com's Avatar
Wiki Edits: 21
You probably wont find any either. Relatively obscure engine and old tech. If it ain't SBC it ain't supported.
Build your own. If the header part is scaring you off, find a set of any 292 headers, then build turn-outs to the lakes pipes which is very simple to do w/ some off-the-shelf exhaust tubing bends.
Old 04-07-2005, 02:38 PM
Pony's Avatar
There's a guy on Ebay selling Lakes headers for a variety of old engines and I believe he said he do others if asked. He most likely would just use an exhaust gasket for a guide. His stuff looks good and he sells completed headers or U-weld it kits. He is in collector car parts, under exhaust. Good Luck.
Old 05-20-2008, 07:18 PM
Ask and you shall recieve.
http://www.lakeheaders.com/FordHeaders.html
Low tech my *****.
Old 05-20-2008, 07:53 PM
Wiki Edits: 21
Originally Posted by blueveil
Yep .
Old 05-21-2008, 11:02 AM
nope
"You probably wont find any either."
oops.
Old 05-21-2008, 03:27 PM
Wiki Edits: 21
oops.
Yep .
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 10:36 AM
Engine block hanger (X style) jdreher Engine 0 04-01-2004 12:00 PM
98 Z-28 with old style small block Deeavi Engine 1 11-02-2003 12:41 PM
1986 305 chevy vs. 1987 305 chevy new style small block mtinsley Engine 2 08-22-2003 12:55 PM
Ford Block hugger headers Pilot34Coupe Engine 1 02-25-2003 06:18 PM
