I think you can come pretty close by measuring the distance the original stud sets in from the back side "outside, trans mounting surface" to the tip of the old ball on the old bellhousing and matching that measurement. If you have a small square that measurement would be easy to make.
If you set both on a flat surface side by side they should measure the same from surface to trans mounting surface. You might have to compensate for the difference in thickness of the stock and Lakewood plate that goes on the back of the engine if there is a difference. The concept would be to have the new ball sitting in the same spot in relation to the clutch that the original ball did. The instructions should be here http://www.lakewood-industries.com/I...?BrandID=5just click on your housing model number. That isn't going to be much help but they have a tech support link. Last edited by Chopt 48; 02-17-2007 at 04:51 PM. |
Thanks guys, I installed it to stock height and we'll see how it goes. I did break my clutch fork at the retainer spring though when I tried to install it. I guess I'll order a new one, maybe two.
Steve |
| Scattershield vs Bellhousing | mrl | Transmission - Rearend | 4 | 01-11-2007 06:33 PM |
| RAM long clutch in Lakewood bellhousing....HELP!! | 70bird | Transmission - Rearend | 2 | 01-13-2005 06:41 PM |
| Lakewood Clutch fork clip broke/angle of clutch fork | 70bird | Transmission - Rearend | 3 | 04-23-2004 07:04 PM |
| Which Lakewood ? | markn | Engine | 1 | 02-22-2004 08:14 AM |
| Richmond T10 and a Lakewood bellhousing - Inadequate fork adjustment | dannyboy02 | Transmission - Rearend | 7 | 12-20-2002 05:27 PM |
