large journal rod - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-02-2004, 11:49 AM
large journal rod
Hi guys,
A little triva for you Chevy guys. Ever seen a large journal (as in a 350 for example) rod with 11/32 rod bolts?
Thanks
Jeff
Old 04-02-2004, 01:10 PM
King of my Man-cave.
Nope. What's the story?
Old 04-02-2004, 05:15 PM
Rogers Performance's Avatar
I think what you might have is that some one cut the rod to large journal.thinking that it was.
mike
Old 04-03-2004, 08:39 AM
Hi,
I just found 7 of these rods yesterday buried in the shop, I had kinda forgot about these rare items. This rod has a dipple like the high perf rat rods and uses 11/32 bolts. To the best of my knowledge all 1967 350 295 hp Camaro engines used these. I have worked on several of these engines (still have 1) all had this type rod with a steel crank. The block is unique also it is the only large journal main (350 size) that used a cannister oil filter, and had a vent (pcv) port cast into the rear of the block like a 327, only larger mains. Not real important info but kinda neat.
Thanks
Jeff
Ps
I think only the vehicle to use the 350 in 67 was the Camaro. Spmething else a little strange- anyone seen an early Chevy II block?
