large valve stem diameter - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-15-2010, 09:43 AM
9K-sbc's Avatar
I recently ran across an sbc with unusually large valve stems, in fact they measure 0.456". Has anyone ever seen valve stems this large? Attached is a photo of the assembly, the roller tip on the rocker is 0.368" and as you can see, it is larger than the stem. Heads are old brodix -8, spring installed height is 2 1/8", spring diameter is 1.560". They were measured with dial calipers, not a micrometer because they are still assembled so give or take .001" or 2 on the stem diameter. Anyone seen this before?
ID:	45662   Click image for larger version
Old 05-15-2010, 10:41 AM
BOBCRMAN@aol.com's Avatar
That is a "lash cap" a hardened cap that sets over the valve stem. The valve locks are relieved to clear the cap. These are commonly used on high lift drag race type assemblies.
Old 05-15-2010, 03:08 PM
ericnova72's Avatar
More for Less Racer
Like Bob has said, your heads are equipped with lash caps, which are hardened pieces that sit on the valve stem like a bottle cap on a beer bottle. Common racing stuff to either/and/or protect the valve tip, add surface area for the roller tip , or height to keep the rocker body from touching the spring retainer.
Fabricating intake manifold. gemini86 Engine 25 10-02-2009 01:10 PM
Valve Stem to Guide Clearance Question y2k600f4 Engine 4 09-04-2009 11:13 AM
Piston notching for valve relief/clearance OHD Engine 9 09-16-2008 10:27 AM
cam question, any truth to this? 406 ss monte Engine 6 03-30-2008 11:28 AM
Valve stem size 87442lover Engine 9 10-30-2003 12:06 PM
